if the boiler is trying to fire up, then locks out, you have a problem on the heating system. once that's sorted, the RCD problem will probably disappear.
Are the isolating valves on both the boiler Flow and Return open??
Yes, Ive said I have energised circuits without gas bondimg in place, simply to perform functional tests.Ill hold my hands up, not good practice.
it really was how things panned out though, honestly.
Ive had to retest the whole caboodle again anyway in light of problem so i may aswell have gone home.Surely only have to do PFC test again though?
Instead of help you get criticised about the bonding? Who cares, the house is empty, probably plastic too. How many houses have you seen with no bonding in use for year on year, or relying on the bond on the water for an earth path at all being picked up via next door. Break it down and test it out. That said you should've just gone home.
Sorry guys.
RCD could be faulty, but as I said it tested fine without gas bonding but not at all with!? I'll swap RCDs round tomorrow.
Dont know if vavles are open or shut. Ill check tomorrow.
Sorry guys.
If the push button test isn't working, and you've connected it correctly then there's no "could be" about it at all...
You didn't IR test it did you?
Sorry guys.
If either of the isolators are shut, the water will not circulate through the radiators. The boiler will therefore not fire up.
Hmm
Have you been practicing in the 3000+ club geordie,you know the rules about disturbing the peace in there I hope
Sorry Dad .... I mean Dez.
Not been to the club for a while - well, not since the fire anyway. Is there any truth in the rumour it started in the CU?
Is the new roof on yet?
Very little damage I'm happy to report,it was saved by the leaking pipes you installed,they finally burst and saved the day,Son
Mine too.
Would you like to sit quietly in the corner with me?
I can show you the chords for House Of The Rising Sun, and we can play duets & things !! :)
I think I'm a little worried............... it's disturbing to think I am engaged to someone morphing into Harness69...........
:shuriken:
