Discuss Fault on ring circuit (weird) in the UK Electrical Forum area at ElectriciansForums.net
Hi there was called to a job with fault finding on a ring 120v on one socket 190 on the other the guy had been doing some work in the kitchen by removing a socket and joint it straight through now it leaves the board as a radial so I had taken one socket of getting voltage on the earth and when I isolated the circuit one of the neutral was live and the rcd hasent tripped either weird one
Out of interest, how would removing a socket and jointing it straight through mean the ring became a radial? Apologies if I've misunderstood.
So is it a ring or a radial???
First port of call would be where someone has been recently working, if it’s a recent fault.
Could be loose cable, faulty socket… anything.
Guy done his own downlights and put screws through lots of cables joined them himself then tiled the floor upstairs so I can’t get access to the joints plus leaking radiator which he had a shock off he’s loves diy but iam not sure it’s for him
Looks like it's time for some big holes in the ceiling and replacing all this guy's wiring.
Reply to Fault on ring circuit (weird) in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
