Discuss Faulty MCB. Problem isolating ring final circuit at CU with MCB in the UK Electrical Forum area at ElectriciansForums.net
maxeon
I am planning to move a socket outlet. The CU is largely unlabelled so don't know which 32 MCB to switch off. There are 2 x 32a MCB. All other mcbs are for lights (6a) and a dedicated immersion (16a).
To isolate the circuit, I tried switching off the first of the two 32a mcb which isolated some of the sockets but not the one I need to move. So I switched the 2nd 32a mcb off too (so now all/both 32a MCBs off but some of sockets still live.
So I tested RCD and main switch which tripped all sockets other circuits off.
I am assuming there is no cross over of ring circuits and that the 2nd circuit is not picking up a live from elsewhere (heavens forbid) although I then switched off all MCBs on all circuits and the 2nd 32a circuit was still live.
Can I conclude that the 2nd MCB is faulty and so not switching off and needs replacing or is there any other possible cause?
I'm an amateur so please bear with me and this is my 1st post.
I'm an amateur
Do you have a two probe voltage tester.
First thing us to ensure that the MCBs are actually disconnecting when they are switched off.
Next you'll need to go done investigating yo find out which MCBs feed which sockets.
Put coloured stickers on the sockets so you don't get lost.
That should give you a starting point. If you can't cope with that simple stuff, then an electrician is what you need.
as above excellent advice. you need an electrician with the appropriate tools/test gear/ knowledge to sort this. you could fit your extra socket by isolating the whole installation, but there sounds like there's a nasty lurking away somewhere and to be honest, you won't have a clue how to find and rectify it. it could turn out to be fatal.
I have a multimeter basic model but works ok. I am always very careful to check and double check that a circuit is actually isolated realising that RFCs can be cross linked by someone not paying attention to detail in there working practices. My double checking with instrement and a lamp before actually working on the circuit, lead me to find this problem. I appreciate I could simply flip the main switch and isolate the whole installation but I relaise that would not address the potentially serious problem. I suppose I was just wondering if a faulty MCB is the most likely cause bearing in mind I had switched off all other mcb including lighting/immersion circuits.
I had started to map out the mcbs to the outlets so as to get the CU properly labelled but then very quickly came across the issue. I think the next task is to check each/every MCB is actually switching off which may hopefully narrow down the problem.
Reply to Faulty MCB. Problem isolating ring final circuit at CU with MCB in the UK Electrical Forum area at ElectriciansForums.net
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
