stummish
Hi all bright sparks,
I've had a question from a client I couldn't answer on the spot. I've done some google research but can't find an answer to this;
Is there any reason the DNO cable and a final circuit be installed in the same trench? DNO cable will be in a duct, client wants the SWA dropped in next to the duct.
There's a new supply being installed from the roadside 25m down a private driveway (5 trees next to driveway so there will be a lot of roots etc) to the new cutout position, and they want up lighting on the trees. My client doesn't want to dig any more trenches than is absolutely necessary, so is there any reason i can't drop my SWA in the same trench as the DNO cable as it takes the same route. I can't find a reason in 7671 (maybe I'm being blind), and I can't find anything about it on google.
Personally id like a separate trench so the 2 cables never get confused in future, and if something ever did go wrong with the final circuit, the DNO cable wouldn't be affected. I'd like a lot of things, most of which i probably shouldn't do
, but is this case is it an absolute NO!
Thanks in advance.
Thanks in advance.
