HappyHippyDad
Supporter
I have been asked to fit the following
A Glimpse Mirror and shaver socket.
Overall dimensions: 50cm H x 39cm D and weight is 6.2 kg's.
I think it should be ok on a plasterboard wall but just wanted some opinions (with regards the weight)? I wont be able to locate it on any joists because of where she wants it.
Cheers all...
I would think it would be OK with four fixings.You could always use the ones with wings that open up when you push them in.
I had this a couple of years ago with a large heavy mirror light, used them toggles with wings on as described above, a bit awkward to fit, be prepared for some effing and blinding. but did a good solid job once fitted!!!
same here.used them for various heavy things over the years and always a good solid fixing
Either metal screw fixings as per Julian (I prefer the Spitt ones) or spring toggles. Both have their downsides but both will do this job easily. Given that screw fixings are cheaper, I'd try those first - if you're not happy then at least you've got a hole left roughly big enough for the screw toggle to go through!
Just remember, the weight is downwards and not under any kind of leverage. Rawl do a good range of fixings suitable for plasterboard, but just make sure you have a decent selection of quality screws (no.10 or 12 will be needed), although if using the metal ones Julian recommends you need to use the ones which come with them.
I have no issue with fixing heavy loads to plasterboard walls, even heavy heated towel rails. It just takes a while to get a feel for what works best with different board, so take some filler just in case (or practice on your own wall before you go) :)
normally takes 3 working days for the customer's cheque to clear. you don't want it falling off before then. :shout:
Find the stud and screw into that
Don't forget to run 3 core to it, customers love it when the shaver light comes on with the main light (and still runs the shaver point 24/7) ;)
Thanks all, thats reassured me :D
Thanks Guitarist,
The lady was kind enough to give me the mirror so I could have a bit of a play. I really like using the twirlies (spitt) so will probably use those, but its good to hear all the responses saying it will be fine. I thought it would be, but the backup is reassuring.
