Discuss Flush Mounted PIR in the UK Electrical Forum area at ElectriciansForums.net
M
monkee
Morning all,
does any one else have problems with a sertain make flush PIR ( Danlers ) xs
is there another option it still gets effected by the wind
thanks...
Never heard of that before monkee, Danlers is a quality product, I have had lesser PIRs come on when heating in the room rises to the detector and customers complaining it comes on in the middle of the night, never heard of wind causing issues though, are you sure it is not just a one off faulty piece?
I recall having issues with these a few years back. Found the problem to be the BMS, some idiot decided to cut the control live to switch the lights off. This resulted in a whole host of symptoms, lights permanently on, lights not turning on, etc. Once we removed this, we reset all units, and most lived.
I remember thay came out with sealed unit then the extra sealed unit, if you look thay stuck a bit plastic ( tape ) around the rim of the fitting white on the face and black inside.
just put out to see if any one else had the same issues.
thanks for any feed back cheers guys
Reply to Flush Mounted PIR in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
