Discuss Flush Solar PV on a Zinc Roof. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Pymmie
I have had an enquiry about fitting Solar PV 'Flush' on a zinc roof.
Has anyone had experience of this before.
Thanks in advance
Regards
John Pym
Solargold SW Ltd
Does it have vertical seams? What Spacing? What's the slope/pitch?
Thanks for prompt reply.
I haven't seen the drawings yet, but wanted to go prepared to the first site meeting.
The last job I did for the developer was a similar house with vertical seams at about 30 degrees spaced at around 500mm.
Regards
John Pym
This may (or may not) help:
ISO 14713-2:2009 Zinc coatings — Guidelines and recommendations for the protection against corrosion of iron and steel in structures — Part 2 Hot dip galvanizing
Be very careful on this one!
Ive done a couple of them and as an ex roofer I've been more than a little dismayed by the lack of knowledge of the roofing contractors installing the roof - and they were a manufacturer approved contractor.
The zinc roof is held in place with a clip thats folded into the seam of the roof, the clip is typically 0.4mm thick roof material with virtually no uplift resistance. This is in turn screwed into the decking material under the roof. Therefore when you come to design the rails to hold the panels to the roof and you are only applying your uplift load through the two support rails you end up concentrating the uplift load into one very small area were the S5 clamp touches the seam (S5 is the way to go).
The roofer should increase the density of clips in the seam to increase the uplift resistance, on our jobs needless to say the roofer didn't do this (despite being asked) and therefore we had to put in additional rails to spread the loading. The structural calcs were a complete nightmare and had our structural consultants baffled for a couple of weeks.
We ended up with some of the highest load areas with 6 runs of rails to spread the load into the seam. It was a coastal job so very high wind loads and the zinc is really very weak and can't take much loading. In our case the roof was Rheinzinc.
So be careful from the structural point of view and carefully consider not only how your product attaches to the roof but how the roof is attached to the structure underneath.
Of course you can just fix it how you would normally and blame the roofer when the system is in the carpark still attached to the roof skin!:smile5:
Reply to Flush Solar PV on a Zinc Roof. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi wondering if you could help with some advice Been running an Essex/suffolk based electrical firm for last 20 years, mainly light commercial...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
Help please, this is my first post on this subject regarding solar panel / battery installation into house with 3 phase supply. I am a DIY level...
guys i have a question regarding gse in roof trays (portrait) and ja solar 395w all black panels GSE say the 395's fit but they dont according to...
