Discuss Frost stat to s plan heating system in the Central Heating Systems area at ElectriciansForums.net
Depends on the boiler. Some have terminals specifically for the frost stat if not it can be wired as in the the diagram. Always best to check the boiler manual first though.
So in this diagram frost stat connects to same terminal as room stat.
Will have a look at some boiler manuals and see which have dedicated terminals
thanks
In the diagram it's wired parallel to the roomstat and programmer. I know some models of worchester Bosch do the dedicated frost stat terminals.
Frost stat detects the cold which then asks the pipe stat (wired in series with the frost stat) if the water in the return heating pipe if it is below set temp if so the switch wire from the pipe stat should connect to the switch wire of the the room stat to bring boiler and pump on
On a s plan system, is it normal to just make the frost stat open one valve, in turn firing the boiler? So any other heating circuits wouldn't have protection.
or is it best to fit a frost state for each heating circuit?
I ve always fitted a frost stat next to the unit it is to protect.
IE an external boiler in an outhouse or against the outside wall of the house would produce enough heat to switch the frost stat off.
Or as at home, my integral garage has a radiator and its own zone valve. The frost stat is above the rad and it drives the valve open which fires the boiler and pump. Pipes to the radiator go past the washing machine and protect it. Radiator heats up and the stat switches off.
Boydy
Reply to Frost stat to s plan heating system in the Central Heating Systems area at ElectriciansForums.net
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi does anyone have a S plan wiring diagram that incorporates a third zone to accommodate an underfloor heating system like polypipe? Would...
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
I generally consider myself pretty up on heating systems but this has me slightly stumped… An otherwise very simple system boiler on what I...
