Discuss Fused spur rating for electric underfloor heating in the Central Heating Systems area at ElectriciansForums.net
Builder installed 175w / sq metre in an area 6.7 x 3.5. What should the fused spur be rated at and should it have a contractor as well?
Am I correct in thinking it is drawing just over 17A therefore 13A fused spur is insufficient?
Is the spur (aka FCU) getting warm? I would probably switch it off until you have got to the bottom of things.
6.7 x 3.5 = 23.45
23.45 x 175 = 4.1kW
4.1kW / 240 = approx 17A
Depending, as Mike said, whether this is mat size or room area.
OP, is the FCU ('spur') warm?
ask when he's taken the washing off of it.
2 cats shat on 2 mats.
stapled their tails together. Siamese cats. ?
We have not heard back from the OP on the size of the mat or room, everything else is guess work, including how many cats are sat on the mat.
and a roll of A4 paper to print off the lecy
6.7 x 3.5 = 23.45
23.45 x 175 = 4.1kW
Thanks everyone, that was the room size....the problem was the fuse was blown and casing burnt...checked with the builder who installed it and the fused spur should have been 20A, but the matting is slightly under the size I quoted making it just under 16A which works for the Stat (but not clearly for the switch).
Thanks everyone, that was the room size....the problem was the fuse was blown and casing burnt...checked with the builder who installed it and the fused spur should have been 20A, but the meeting is slightly under the size I quoted making it just under 16A which works for the Stat (but not clearly for the switch).
I think you need to get your builder to pay for an electrician to put this right. And point out to him what he has done wrong - I bet he's done this in other properties as well.
Reply to Fused spur rating for electric underfloor heating in the Central Heating Systems area at ElectriciansForums.net
