Lister1987
Trainee
So just been to view a new place as me and the brood are on need of a bigger place and noticed a few things that concerned me, unfortunately I didn't think to get piccies;
As title, gas and electric meter share the same cupboard and are more or less on top each other - Regs regarding this are?
Couldn't see any immediately obvious cooker isolator and agent had no idea, regs re placement of a cooker isolator?
I've asked the agent if the property has a recent EICR as I want to make sure its electrically sound before our 2 and 1yos poke fingers etc etc
Could see undersink plumbing for washing machine/dishwasher bit no obvious location for them so asked agent to find that out.
Anything else I should be looking for?
Cant see an issue with both meters in the same cupboard, makes it easier to bond atleast. A house i lived in had all sevices in a small cupboard.
Are there any electrical services or cables ( other than bonding) touching the gas pipes.
Well that contravenes the gas reg given to you by @Corbs .
See also 528.33 to 528.3.4 and the accompanying note on the segregation of low pressure gas systems, where more information can be found.
gas regs is 150mm between main tails / wires and gas pipe
wrong. cables and gas pipes spacing is 25mm. gas meter and consumer unit 150mm spacing.
None. There is no requirement for a cooker isolator apart from the MCB in the CU. They are often fitted as "nice to have".
