Discuss Generator connection to mains supply questions in the UK Electrical Forum area at ElectriciansForums.net
Hopefully the N-E fault you have found is enough to explain things, though to trip a 100mA RCD you would need > 50mA and at 400 ohms that is 20V N-E which is really quite high for any sane cable voltage drop that you would plan (e.g. 5% is 11.5V and if L and N cables identical, then under 6V drop expected along N to appear N-E).
But it needs fixing anyway, so one done check and see if it has solved it.
Reply to Generator connection to mains supply questions in the UK Electrical Forum area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
How should grounding be made to a 20kVA single phase generator set feeding a domestic property via a manual change over switch? At the generator's...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
