Discuss Generators in the UK Electrical Forum area at ElectriciansForums.net
E
electrosistemas
Any body with knowlege onSDMO 400 KW gen sets wanting to talk abou it?
I am having a litle problem with the speed acquisition device into one of these!
The engine will not show on Telys controller the rpm. Consequently will stop riuning. Just tryed to reload the software from USB stick but it will not go due to missing Esc button on Telys. Will have to use lap top, cable and apropriate software.
Many thanks
Without pointing out the obvious have you checked the mag pick up? its in the flywheel housing between the engine and the alternator, unscrew it and count how many turns you remove it clean it (normally the best thing is on a car tyre!) then re install. if you loose count wind it all the way in until it hits the fly wheel then un wind three quarters of a turn.
Thank you borg247. We had it out allready. It is a magnetic device that probably will see magnetic and non magnetic material on the flywhell and generate a certain wave form on it's coil. it is just attached to the housing you say with 2 M5 halen screws. It's signal is directed to a CAN BUS sytem that interacts with the Telys controller software. This pickup does not have any erosion or dirt. I think we must try the software again. Regards
Before you cause some expensive damage get the manufacturers involved. If they damage the machine then it’s down to them.
You clearly don’t know what you’re doing.
Hi,
Isn't that how us old sparks gain experience? I always found the best way to learn was to find the fault and sort it, invaluable,
I do see where you are coming from though,
Regards.
Reply to Generators in the UK Electrical Forum area at ElectriciansForums.net
And now for something completely different! I have been after a power station telegraph for decades and due to the fact most would have been...
Good day all, I'm writing from the Commonwealth of Dominica (NOT Dominican Republic) where we have single phase 230V, 50Hz. I'm managing a...
I am not an electrician, but have one that is not very familiar wit generators. The planer is a 5 hp 20” grizzly planer with magnetic switch and...
Hi All Had an enquiry about installing a generator fed UPS to a house. I have a minimal amount of experience with UPS but am certainly no expert...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
