• Please checkout this (ad-free) update post I've done on a spare blog. Feel free to bookmark it and check everynow and again for update if ads are pissing you off. Always feel free to ad-block them for now though if you want. I'll let you know when you can disable the ad blocker again, only if you want to see the ads. They should look nice and neat in the end.
Discuss GFCI won't reset, small voltage neutral to ground in the Electrical Forum area at ElectriciansForums.net
marquisgt
I do general maintenance at a summer camp that includes a campground. One of our campsite electric posts is having a problem. The GFCI is tripped and will not reset. I tried a new GFCI outlet and same result. I'm also getting about 2.6v from neutral to ground, when measured at the outlet and at the breaker box with no load on the circuit. There is also nothing connected to the LOAD side of the GFCI. I get about 118v Hot to Ground and from Hot to Neutral.
Nothing has changed on the circuit that I know of. Any ideas on how to fix this? Let me know if I need to provide more information.
Reply to GFCI won't reset, small voltage neutral to ground in the Electrical Forum area at ElectriciansForums.net
I have a towel dryer on an interior wall in my bathroom, wired off the last stop in my loop of bathroom outlets. This thing has been installed...
Hello, I had an electrician install a 100Amp subpanel which feeds a mini split. I addition I added a Homeline 50A GFCI breaker to power a shed. I...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
Weekend sparker here, I have a sqd 2 pole 50amp GFCI breaker it was mounted out side in a service box, have not had a problem till now 3yrs old...
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
New Posts (Please Reply)
