Discuss Glass v Ceramic Fuse in the Australia area at ElectriciansForums.net
P
pin145
I have a travel adapter that has blown a fuse due to using a hairdryer in Cuba.
I need to replace it. The original has a 2.5amp ceramic fuse in it. Can I put a glass type in or does it have to be ceramic? What are the differences between the two?
Tom
Tom
I take it this isn't a British Standard fuse? Either way I would suggest replacing like for like.
I'd hazard a guess that the ceramic has a higher breaking capacity than the glass one as it's getting strapped across the mains. Like for like is good advice.
I usually come across glass types in low fault current applications, eg, protecting electronics. There may be several on a single board and that board may be one of many interdependant circuits so if one goes others might go at the same time. Imagine metering out a racks-worh of in-line fuses. Nasty. Make 'em out of glass and all you need is an eyeball.
Reply to Glass v Ceramic Fuse in the Australia area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Bit of a long shot on here but does anyone have a circuit diagram for a Chavin Arnoux CA 6545 5kV tester? I've copied my post on EEVBLOG forum...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hello, I have a Chinese 90w laser engraver, and recently the power supply went out. While operating, I heard a pop, and when I disassembled, I...
Hello Everyone, I have a technical question that I hope someone can help clarify. We're currently facing an odd issue with a machine equipped...
