Discuss Guess the fault(s)... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Pretty much as the title says...... just a bit of fun
:oops::oops::oops:
I can kinda see the thinking, it's much easier to connect a phase to the body of the fitting than that damn pesky CPC. ;)
It's a special security light,the whole thing becomes live when a nearby PIR is activated to deter bulb theft. [I'd put a bit of red sleeving on the yellow though and possibly black on the blue as it's 'old' colours] :tongue3:
The fixing looks level everything else looks faulty. Instalations like this usually have there own personal tncs conection in an adjacent light switch.
You sure? Don't look quite level to me.
drunk camera?
anyway, it's perfectly obvious. fitting has been removed to make the pointing behind match up to the rest of the bodge. oh, and sleeve that yellow with some earth sleeving. there's a bit spare on the stripping wire.
Ha ha.
The homeowner wasn't in so I just did some basic checking:
so apart from the obvious line and neutral reverse, the line was permanent live, and the yellow was the switched live, causing the rusty parts of the case to become live when on, so my guess is some muppet took off a security light with a manual override!
So if it had had a lamp bulb fitted it would have been on all the time, and when the switch was on, the case was live ! I guess it was still security fitting!
You get a shock Clive ?
Bad that lol. Funny how stupid and clueless some people are. One for the 'if it works its obviously fine' brigade.
Given the degree of muppetry and f'kwittery that has gone on here, I can't understand why they didn't also snip the cpc off right at the end of the cable. Small mercies, eh?
Because they had no snips, it's hard to use a trowel to chop cables and double up as a screwdriver.
Ah, fair enough. I was assuming they'd just use their teeth. Must not've had any left.
I had a client a couple of years back that thought the L2 on a two way light switch was where the CPC went.....he was a 'proper' engineer allegedly....
As someone who now works in security I would say that this is the perfect security light. Turn it on and not only can you see what you are doing, but you get to see the shocking sight of anyone dumb enough to try nicking the lamp (bulb):nopity:
Reply to Guess the fault(s)... in the UK Electrical Forum area at ElectriciansForums.net
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
A silly fault in a circuit only 4m long is currently eluding me! This is ECIR remedials of a landlords supply in a block of flats. Circuit 2 =...
Today I was doing an EICR and went around a couple sockets with a Megger MST220 socket tester just to see if there was anything obvious, all three...
