Electrical2Go - Online Electrical Supplier
Advertisement - Content continues below
Discuss Hager Din Rail Mounted Time Switch in the Electrical Forum area at ElectriciansForums.net
Deleted member 105166
Has anyone fitted these into an Invicta 3 Type B board?
Wholesaler asked Hager whom stated they need to go into a separate enclosure, but couldn't elaborate on why. My preference is to mount them in the DB under the corresponding RCBOs and I cannot see from the spec sheet and photo why this should be problematic. Perhaps I'm missing something?
uHeat Banner - Forum Discount Available
Deleted member 26818
  • #2
18th Edition now requires Manufacturer’s Instructions to be complied with in regards to DBs/CUs.
  • #3
I appreciate that spin, and am trying to establish whether the second/third hand information I've received constitutes manufacturer's instructions, or a lack of understanding of the original question or the desire to find out and explain with a reason that makes sense, as opposed to "don't know". Hence my asking on here, as the forum is always a great source of answers from people with real experience.
  • #4
I can’t see anything on the data sheet that says they comply with BS EN 60947-3.
As such I would not consider them as being suitable for installation in a DB/CU.
SparkyChick
Mod
Mentor
I'm currently designing a lighting setup for a client that's going to rely heavily on contactors, timers etc. I'd have no qualms whatsoever about sticking any of those Hager devices in a Hager board. They are listed on their website as modular devices within the energy distribution section, but if you want it in writing, I'd just drop Hager technical a mail, I've always found them to be really helpful and pretty quick when it comes to responding.
SparkyChick
Mod
Mentor
Having seen the range of gear Hager have available for such purposes I just decided to phone them and ask the question as I'm probably going to use it for my project.
Hager gear in a Hager board, no problem what so ever was the response.
SparkyChick
Mod
Mentor
I will add, it's worth downloading the product catalogue though and looking at the devices. There are some rules it seems around device placement and the use of heat separators for example next to contactors.
SparkyChick
Mod
Mentor
I think where it might stem from is this:-
"Dimmers, time switches, meters and thermostats are among our varied range of devices, and they can all be perfectly housed in our expansive range of enclosures to tailor a building’s energy to an individual’s style. It’s just like a home, miniaturised."
This is a paragraph of text from the header page for section 2 of the general Hager catalogue that covers modular enclosures and devices. Which could be interpreted as meaning the devices have to be installed in one of their modular enclosures.
I'm looking into it because Spin's comment got me thinking, but I can't find anything stating you cannot install the devices in a consumer unit, likewise I can find nothing against a consumer unit stating you can't install the modular devices in them.
But there is this blanket statement:-
"The relevant part of the BS EN 61439 series applies to the integration of mechanical and electrical components (switching devices, control devices, busbars, functional units, etc.) into an enclosure. Hager systems such as consumer unit, distribution board and panel board ranges are certified to the appropriate part of the BS EN 61439 series."
So I think it's fine :)
  • #11
I'm pretty sure you connect those with cable as they don't fit on a standard TPN busbar prong.
Indeed - they don't incorporate a CPD, so depend on one upstream.
Charlie_
I’ve fitted loads..
Either put them on the din rail adjacent to the main incomer or in an expansion chamber
Aico 3000 Range
Reply to Hager Din Rail Mounted Time Switch in the Electrical Forum area at ElectriciansForums.net
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Top Bottom
