Discuss Height Of Electrical Socket And Switch Outlets in the Canada area at ElectriciansForums.net
What is the correct height for both sockets and switches in Scotland?
I have always been fitting them at 300mm and 1370mm however a building control Officr has intimated they should be at 450mm for socets and between 800mm and 1200mm for switches.
Is this the case?
well he is taking the same height as Part P of the building regs, which as you know, does not apply in Scotland
Even under Part P, these regs only apply to new builds, and then only to rooms normally used by visitors (unlless the property is for specifically for a disabled person) so they do not apply to the kitchen or garage
BS7671 does not specify height of switches and sockets (to my knowledge)
The Scottish Building Standards Crowd Says It Should Be These New Heights. This Is A Top Floor Flat With No Lift Really Suitable For A Disabled Person Aaaaarrrrggghhhh!!!!!!!!!!!
Just for info; OSG16th does make reference to Building regs and switches etc must be between 450 and 1200 mm. Does this apply to extra sockets installed? On the point of mounting heights; haven't read the 17th yet as have just done my 2391 to the 16th and didn't want to get even more confused!! Do consumer units now have to be fitted between 450 -1200 and, if so, will this not leave them open to damage by knocks and bumps??
Jeremy
I have asked the building control officer a couple of questions
Can you answer a couple of questions for me please?
I have been asked to provide a quotation for a rewire of a flat in Haymarket and all the existing sockets are on a beautiful big skirting board, the client wishes all the sockets to be at this level (about 100mm from floor level). Can I do this or have they all to go at a minimum of 400mm as per 4.8.5 or does aesthetics of the room come into it?
Is there any time when there is a relaxation of these heights for electrical outlets?
I will post his answers when I get a reply:)
As i have said previously, the building regs requirements only apply to new builds
If you are refurbing this flat, it is quite acceptable to keep sockets switches etc at their existing height providing that they are "no less accessible than they were previously" - this generally applies to things like CU's, I have seen a building inspector pick up a job where the CU ended up in a cupboard under the stairs after an extension was built, where it was wall mounted previously
so as long as your switches / sockets dont go any lower, then you are ok
Shakey Thanks For Your Help
The Building Control Officer Told Me It Comes Into Effect If The Building Warrant Was Applied After 7th April This Year.
I Am Still Looking For Clarification On This From Him
Reply to Height Of Electrical Socket And Switch Outlets in the Canada area at ElectriciansForums.net
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
A simple outlet, 110v a single (2) outlets on the left side of the box, a spst switch on the right, with a single cover, covering them both. The...
