Discuss Help!! SINGLE 1 GANG DIMMER LIGHT SWITCH SCREWLESS.. How to connect??? in the Australia area at ElectriciansForums.net
M
Martin J MIles
I have just bought a Dimmer for my room, Also had rewiring done about 6 months ago I have 2 wires 1 blue 1 brown... I have tried to connect them to L1 and L2 which didnt work and now I have the blue in L1 and the brown in C... this works but the dimmer doesnt actually dim..!! Any helpwould be gratefull thanks
Reply to Help!! SINGLE 1 GANG DIMMER LIGHT SWITCH SCREWLESS.. How to connect??? in the Australia area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, Trying to wire this 3phase switch as single for a table saw, told I could do this from guy at Haymans, even told 2nd time which wires to...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
