OP
wallyanker
I did the IR test - coming up as water digress in the cables and circuits are corroded
What readings did you get?? The tester will not display water digress on the screen :smile5:
Discuss HELP! Water leaking through the light pendants from upstairs flat in the Electrical Forum area at ElectriciansForums.net
Didnt say it did. A visual inspection did.
That's not what you said at all?
can see this forum is run by a bunch of bullies who offer no relevant sound advice to a situation. But read into my words,turn them around in the attempt to riddicule me.
Reply to HELP! Water leaking through the light pendants from upstairs flat in the Electrical Forum area at ElectriciansForums.net
