Discuss Help with wiring diagram at outdoor light switch box in the DIY Electrical Advice area at ElectriciansForums.net
Hey all quick question. Hooking up a smart switch and wanted to ask if I am right on my photo here. The white wire with the white cap on the end is likely neutral (tested no current)? The yellow capped one is line (tested hot) and the orange capped would be the load (tested no current)?
Previous hookup only had the presumed load and line hooked to it. The presumed neutral was not in use. Thanks ahead of time. Sorry if my question is kind of put out there goofy.
Yes. That sounds right. The neutrals are connected together.
hard to tell the colours there as everything has been painted over.
As you’re American, best wait for @Megawatt to reply.
Reply to Help with wiring diagram at outdoor light switch box in the DIY Electrical Advice area at ElectriciansForums.net
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
