Evening All another odd question (I love my customers)
There’s no 10mm or 6mm cable in their kitchen, apparently when it was wired there were all 13amp eco appliances. Anyway a new couple have bought it and want a 5 ring hob installed but the kitchen is done to a high standard so they don’t want trunking or walls chased (kitchen in single story extension. The board and job location are on the outside wall. Can I run a 6/10 mom cable through the wall outside the back inside for for the hob connections obv the cable would be aremourd or SY. Is this doable or is it a case of no can do
I wouldn't have either externally on my house......and no I'm not a snob just wouldn't want a fat cable on show with loads of cleats showing.
Personally if I couldn't convince client to bite bullet and mess up kitchen I'd silly price job and if accepted I'd do it in conduit or if possible dig trench and hide swa?
None of us have (except the OP) seen the job though. The external run might be only for a few feet. The exterior of the house might be hideous and unkempt. The run might be in a side passage that is virtually never used. Solutions and their costs can be provided and the client can then decide.
6mm t+e run through 25mm conduit on the external section would be simplest. Don't really like t and e in conduit, but no point adding unnecessary joints for sake of it, and twin will be easier to route on the internal sections.
I tend to agree with the above...
Domestic install , only (easiest) route is external , depending on the oven/hob I would go for 4mm in 20mm pvc conduit or 6mm in 25mm pvc conduit.
It ain’t perfect but nothing in life ever is.
Swansea
Hob cable outside then in
Scott Jacob,
Doomed,
