Discuss Honeywell Alarm Accenta G4 alternative in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi,
Im an electrician but have been installing the odd alarms for some of my customers too.
Used to use the Honeywell Accenta G4 with the dialler facility etc with no problems. However it seems Honeywell have discontinued this easy to install system.
Could anyone recommended a replacement wired system ? Galaxy G2 any good?
Many thanks,
Sean
Texecom Veritas range, I generally use the Veritas Excel which has the text display on the keypad and wire it as an EOL system with resistors so each circuit shows a tamper if the cable or dectector is damaged
Thank you very much. This great help and I will look into it.
Reply to Honeywell Alarm Accenta G4 alternative in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Good evening looking for some advice. I have a honeywell galaxy g2 alarm system that i have inherited with a pub I have taken over, I need to do...
hello all, I have a Honeywell Galaxy G2-20 burglar installed in my home (about 9 years old). Recently I got a Battery Miss fault showing on...
6K
Struggling a touch at the minute with customers getting work done by “someone they know” and citing our quotations being too expensive as the...
I have just installed a Honeywell Accenta G4 system. All ok apart from 2 queries: The entry/exit zone 1 is a PIR (there are no door contacts on my...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
