S
Seanuk
Hi,
Im an electrician but have been installing the odd alarms for some of my customers too.
Used to use the Honeywell Accenta G4 with the dialler facility etc with no problems. However it seems Honeywell have discontinued this easy to install system.
Could anyone recommended a replacement wired system ? Galaxy G2 any good?
Many thanks,
Sean
Texecom Veritas range, I generally use the Veritas Excel which has the text display on the keypad and wire it as an EOL system with resistors so each circuit shows a tamper if the cable or dectector is damaged
Thank you very much. This great help and I will look into it.
Honeywell Alarm Accenta G4 alternative
Seanuk,
Seanuk,
