Discuss Hot water direct to solar panels in the UK Electrical Forum area at ElectriciansForums.net
If you want to heat water with solar panels surely it would be best to get solar panels that heat the water directly. I have seen some panels that are electric but have water piped to them as well, seems the best of both worlds.
They said they've already got PV.
Eddi, Immersun, Solar iBoost all do immersion controllers. If thinking of an EV charger in the future then Eddi is already setup to work alongside the Zappi, etc.
Had a client in the past with an Immersun and an EV Charger (can't remember brand but it was also setup to utilise any power which would otherwise have been exported to "top up" the car battery if required). The two controllers ended up fighting each other which meant neither worked properly.
Reply to Hot water direct to solar panels in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
I have a 4.8kw solar diverter with 2 x 4.8kw hot water systems. Is there a switch that will only heat one hot water system at a time and switch...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
