N
Novice12
Hello,
I recently had house rewired and was left the Domestic Electrical Installation Certificate for the work.
In the "Details of the Installation" section it had "New" ticked under "The installation is" part so i.e. is saying is a new installation.
I later received a Building Regulations Certificate of Compliance for this work from NICEIC.
However the work was not fully finished at the time the Domestic Electrical Installation Certificate was filled out, dated and signed and since then a few bits more were done to finish the job. These included adding a socket to a loop that was ready for it, adjustment to wiring to another socket and installation of an extractor fan.
I pointed out to my builder that work had been done since the Domestic Electrical Installation Certificate was filled-in and as I understood it it should only been signed and dated once all work is complete.
He has now got Electrician to fill out, date and sign another Domestic Electrical Installation Certificate done after the all the work actually finished.
However the new Domestic Electrical Installation Certificate is marked to indicate the installation is "An addition" and not "New" even though in the "Details of the Installation" section it still says that the work is a "full rewire to property..." etc.
Should the new Domestic Electrical Installation Certificate be marked to show the installation as "new" still?
Also how will NICEIC deal with this new Domestic Electrical Installation Certificate when they receive it? Will they just issue another Building Regulations Certificate of Compliance or will they question why they have got it again from the Electrician etc.?
My other concern/question is that I think in the "Circuit Details" section some of the numbers re. things like lights and sockets may be incorrect. For example for some of the "Number of points served" entries the number of lights seems to be too high compared to the actual number of lights; will this cause me any issues down the line, for example when come to sell, if these don't tally? Also If a light switch turns on multiple light bulbs such as bathroom ceiling lights are these lights counted as 1 point served or is it 1 point served for each actual light bulb? This might go some way (but not all the way) to explaining the differences in numbers written on the form and actual numbers in house.
Also the Building Regulations Certificate of Compliance has no referrence to the extractor fan.
Any help to understand this would be much appreciated.
