Discuss How this wires has been pulled? in the UK Electrical Forum area at ElectriciansForums.net
M
Mixmaker
Hello everyone! Does anybody know how this 3 cables from loft has been pulled down to first and ground floor,if the coming through 3 holes in the wall.?Is there any specific method of pulling wires?Please help. Thank you very much.
could even be aerial/satellite cables. out and up to the roof. where's me crystal ball?
stitch drilled out a brick up top and a brick down low then dropped down cavity. use a mortar gun when reinstalling the bricks. not a great installation method as you can't support the cable throughout its length
The Sparky must have been blind pulling his wires like that
It's going to be pretty difficult to be certain without actually being there. Can you see anything else under that insulation? Do they disappear into a flat tube behind the plasterboard in the room below? Can you try a cable tracer? Can you access the flat below and see what accessories are in line with them further down? Daz
Lets just say maybe you are correct, never mind that old tosh about cable support, just be grateful you have got down a cavity and not destroyed the clients house in the process. Geez
Not ideal in the cavity, but if there's no alternative. Daz
Reply to How this wires has been pulled? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
