Discuss How to deal with Pyro Cable? in the UK Electrical Forum area at ElectriciansForums.net
I wish it wasn't so expensive to buy, I could use it much more then!
The 25mm 2core here is around £65 a meter. :eek:
Are you. Saying that there is a single pyro cable leaving the house spurred off the ring?
If this is the case can you not re terminate the pyro into a suitable IP rated box fixed to the building terminating the conductors inside.
Not used pyro for some time it is a bit of a black art now and would think that not many sparkies would be able to do it nowadays.
Might be worth carrying out an IR test on the circuit prior to carrying out any work on pyro. Should last for ever if not disturbed but worth checking to confirm condition and if your work has caused any issues.
Would be interesting to understand your competencies, qualifications, and experiences following your initial comments and suggestions.
MICC Simples, no way is it a black art, honestly. Lost art maybe.
Situation is there's some 53 year old pyro cable that I need to either remove, or make dead, or cut short and push back into the wall having ensured that the still-live end cannot short out the circuit or come into contact with anything.
No hope of fully removing it, as it goes up the cavity and I don't even know the route it takes.
Chances of finding the junction box that connects it to the downstairs power ring are remote, I suspect it connects at a junction box fixed into the wall behind fixed cupboards, next to pipes, in a kitchen, and below the bath (bathroom above the kitchen), however I cannot be sure. I also am not sure I can take the cupboards down without damaging them (I'm no carpenter/kitchen fitter).
SKIP TO THE POINT:
The obvious thing to do seems to be to cut the cable just after it leaves the outside house, fix the end in such a way that it's not going to short the circuit or make live anything it comes into contact with, and shove it back into the wall (then cement over it). I've not had to deal with pyro before, how would you recommend going about this?
I can just imagine at one of the Electricians training centres, "what about Pyro the Mate" ""oh don't concern yourself with that, you wont find any of that stuff in a domestic situation"" "you will never need to know how to work with it, just concentrate on the cubicle for your practical test"
I love those videos! A good drinking game would be take a drink every time she says
Pyrotenax or how easy it is to install!
Reply to How to deal with Pyro Cable? in the UK Electrical Forum area at ElectriciansForums.net
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
