Discuss How to install additional 12V battery to run security systems in the Auto Electrician Forum area at ElectriciansForums.net
You would need to work out what extra security equipment you are going to use and then find a battery or batteries that can be hidden within the vehicle and supply that load for upto a few days or possibly a couple of weeks it may also be worth installing a battery monitor that can report the battery status when getting to a critical voltage. A VSR works in a similar way to a split charge setup but is easier to wire
Thanks, I’ve looked in to the prospect of adding a tracker. The FMT100 looks simple and acceptable. On the manufacturers website it offers the information below on consumption. Based on this, if I were to use a small, compact motorcycle 12v battery of say 6Ah, connected via a VSR, does that sound a sensible setup?
Power consumptionAt 12V < 1.47 mA (Ultra Deep Sleep)
At 12V < 3.21 mA (Deep Sleep)
At 12V < 3.75 mA (Online Sleep)
At 12V < 5.48 mA (GPS Sleep)
At 12V < 24.41 mA (nominal)
Thanks for your response, this sound feasible. Would you be able to explain in a little bit more depth roughly what components would be required and how they would be connected? From a little bit of reading I’m thinking using a VSR to connect the second battery and connect the additional security direct to the second battery. Does that sound correct?
Post up the product you have in mind and a wiring diagram, can comment then
This is the tracker:
This is the VSR:
And this is the sort of battery I was considering:
And this very simple diagram I’ve pinched off of the internet was my plan. Connecting the VSR where is says battery isolator and the tracker where it says amplifier. With an inline fuse either side of the VSR. What do you reckon?
Reply to How to install additional 12V battery to run security systems in the Auto Electrician Forum area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Good Evening All, I'm not an electrician but I'd like to pick the brains of those that are please. Note I intend getting a qualified electrician...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
