Discuss How to install additional 12V battery to run security systems in the Auto Electrician Forum area at ElectriciansForums.net
Hello all, new here.
I’m searching for advice whilst brainstorming the idea of installing an additional 12v battery in my car to supply the security systems. Some context, the car in question is infamous for being easy to pinch as it is easy to access the battery, disconnect it without setting off any of the security systems as they have no internal backup battery, nor battery disconnect feature.
In short then, essentially what I am thinking is installing a second 12v battery that will be charged along with the normal battery, but only supply the security systems. That way the additional battery will always remain charged, but should the primary battery be disconnected and the rest of the vehicle be dead, the additional battery will continue providing power to the security systems.
Hopefully I have explained it clear enough. It seems simple enough but I haven’t a clue how to connect it up or what components are required. Nor do I know what the limitations of choice are for the additional battery. Preferably it can be much smaller and more compact as it is only to run the low current draw security systems and that will allow it to be tucked away discreetly.
Any help or advice is greatly appreciated.
If the thieves disconnect the battery, how do they start and run the car?
Its not straight forward as if effect in your scenario both batteries will be tied together through the charging cct. They would need to be isolated as different batteries at different states of charge when tied together can produce large currents. Usually in this scenario its easier to either have a larger battery or a second battery with a separate charging system, like plugging it into Battery charger at home.
Thanks for your response. I suppose it would be in the instance of the vehicle being towed away or if the vehicle was a motorbike and lifted.
If they lift a motorbike they don't care about the alarm. It will be a battery powered angle grinder to the security chain, and then they lift it straight into the transit van. Probably all done in about 30 seconds.
Would a voltage sensing relay do the trick?
I would go down the route of a split charge system for a second battery and add an additional 3 party security / tracking / geofencing system to backup the manufacturers security fed from the second battery
Thanks for your response, this sound feasible. Would you be able to explain in a little bit more depth roughly what components would be required and how they would be connected? From a little bit of reading I’m thinking using a VSR to connect the second battery and connect the additional security direct to the second battery. Does that sound correct?
You would need to work out what extra security equipment you are going to use and then find a battery or batteries that can be hidden within the vehicle and supply that load for upto a few days or possibly a couple of weeks it may also be worth installing a battery monitor that can report the battery status when getting to a critical voltage. A VSR works in a similar way to a split charge setup but is easier to wire
Is it really such a big problem with these cars? I mean the fact that they will not be able to start them/run them and will probably need to trailer them away. Most criminals now either clone the keys or steal them from the house.
Thanks, I’ve looked in to the prospect of adding a tracker. The FMT100 looks simple and acceptable. On the manufacturers website it offers the information below on consumption. Based on this, if I were to use a small, compact motorcycle 12v battery of say 6Ah, connected via a VSR, does that sound a sensible setup?
Power consumptionAt 12V < 1.47 mA (Ultra Deep Sleep)
At 12V < 3.21 mA (Deep Sleep)
At 12V < 3.75 mA (Online Sleep)
At 12V < 5.48 mA (GPS Sleep)
At 12V < 24.41 mA (nominal)
Post up the product you have in mind and a wiring diagram, can comment then
This is the tracker:
This is the VSR:
And this is the sort of battery I was considering:
And this very simple diagram I’ve pinched off of the internet was my plan. Connecting the VSR where is says battery isolator and the tracker where it says amplifier. With an inline fuse either side of the VSR. What do you reckon?
Reply to How to install additional 12V battery to run security systems in the Auto Electrician Forum area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Good Evening All, I'm not an electrician but I'd like to pick the brains of those that are please. Note I intend getting a qualified electrician...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
