Discuss How would you do earth continuity on ring circuit in two core MICC cable? in the The Welcome Forum area at ElectriciansForums.net
It’s only the live conductors that need to be proven to be in a ring configuration. The cpc just needs the continuity to be verified between the sockets and the MET
is the micc not in a ring? Or are the cables touching?
Reply to How would you do earth continuity on ring circuit in two core MICC cable? in the The Welcome Forum area at ElectriciansForums.net
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hi! Is there any way to know if I have a ring or a radial circuit in a division of the house? Thanks!
