Discuss I worked out what a neon screwdriver is for in the UK Electrical Forum area at ElectriciansForums.net
well, iv'e just bought a set of wiha slimlines, and they come with a pretty little neon driver with wiha printed on it.
isnt that the noise you make when using them
it's the nois i made when i paid. cost 24 pints!
I bought the Wera set 48 quid with 17 pieces in loads of useful screwdrivers 4 different cab keys and the slotted pozzi type for mcb,s,gonna replace the neon with a voltstick though.
was split between the wera and the wiha. both around same price, bit i prefer the feel of the wiha handle. the slim bits will take some getting used to though.
when i work out how to post pics, ill show you all my test kit--------
ok done it
my multi meter with a 500 volt insulation test built in btw
my amprobe very accurate, it has a slot at the rear of the case to attach it to your belt really cooll!, you look the part
my voltage tester
all that fluke craps cack (imo)
The water had seeped into the device and shorted out the resistor.a neon screwdriver tells you if there is a voltage realtive to your body .In theory they shouldn't work if you're up a wooden ladder with rubber shoes.
For the small amount of current required to run a neon, I suspect that the capacitive coupling between your body and the ground is sufficient.
Reply to I worked out what a neon screwdriver is for in the UK Electrical Forum area at ElectriciansForums.net
