when i work out how to post pics, ill show you all my test kit--------
ok done it
my multi meter with a 500 volt insulation test built in btw
my amprobe very accurate, it has a slot at the rear of the case to attach it to your belt really cooll!, you look the part
my voltage tester
all that fluke craps cack (imo)
that table is terrible imitation wood.
The water had seeped into the device and shorted out the resistor.a neon screwdriver tells you if there is a voltage realtive to your body .In theory they shouldn't work if you're up a wooden ladder with rubber shoes.
For the small amount of current required to run a neon, I suspect that the capacitive coupling between your body and the ground is sufficient.
