Hi, I'm new to this, and I need some advice with my first Bluetooth speaker project. I'm not sure if my plans on doing a portable Bluetooth speaker are correct (is it going to work?). I have 4 18650 batteries (one battery has 3.7V 30A) that I'm going to use for the project. Also I'm going to use AMP (TPA3118 PBTL Mono DC 8-24V 60W Digital Audio Amplifier Board AMP Module Chip 9FR | eBay - https://ebay.to/2WBgsdp), PRE-AMP (NE5532 Tone Board Preamp Pre-Amp with Treble Bass Volume Adjustment Pre-Amp O1P1 | eBay - https://ebay.to/3b8jwD2), an on/off switch, a Decoder board (Bluetooth 5.0 Car Decoder Board MP3 Player FM Radio Audio Module Remote Nett | eBay - https://ebay.to/3ftX3Uw) and also a 4ohm 100w(not sure about the wattage of the speaker) speaker. I also might add an LED strip (AC220V DC12V Waterproof 3528SMD 5050smd LED Strip Light 30CM 1m 2m 3m 4m 5m | eBay - https://ebay.to/2SLzfl2) with a separate switch. The thing is that I'm worried about the decoder board as it's only capable of 12V, im not sure if I can use the 14.8V provided by the batteries or should I lower it with this board (DC-DC Adjustable Step Up Converter 2-15V to 5V-28V 2A Boost Power Supply Module | eBay - https://ebay.to/3fw4QRu), or is it good as is.
Also I haven't decided how I'm going to connect all of these parts (don't have the scheme yet).
Note: I'm going to connect all of it to the same circuit.
Links:
AMP: TPA3118 PBTL Mono DC 8-24V 60W Digital Audio Amplifier Board AMP Module Chip 9FR | eBay - https://ebay.to/2yAgDO0
PRE-AMP: NE5532 Tone Board Preamp Pre-Amp with Treble Bass Volume Adjustment Pre-Amp O1P1 | eBay - https://ebay.to/3bedMrB
DECODER: Bluetooth 5.0 Car Decoder Board MP3 Player FM Radio Audio Module Remote Nett | eBay - https://ebay.to/2L6Gos0
LED: AC220V DC12V Waterproof 3528SMD 5050smd LED Strip Light 30CM 1m 2m 3m 4m 5m | eBay - https://ebay.to/3bb8ayg
DC-DC CONVENTER: DC-DC Adjustable Step Up Converter 2-15V to 5V-28V 2A Boost Power Supply Module | eBay - https://ebay.to/3bkedAJ
More info in attached file, it might be useful.
Links:
