Discuss I'd rather install Ikea light fittings in the Lighting Forum area at ElectriciansForums.net
Previous fittings we've used had the dual spring loaded terminations that are a pleasure to work with but looks like the wholesaler has changed suppliers, no need for spade crimps on the old ones and I have about three left on my van...Yep they are, but you can crimp the cables into a smaller spade like crimp which reduces the size of the conductor and makes it easier to get into the terminals, but Strima knows that.
Not enough room to get 4x 3 way Wagos in the fitting without them applying pressure to the PCB.Connect the singles with wagos in the back of the fitting and use a short length of singles to the terminals.
Those terminals don’t provide a sound connection for two conductors.
Can't have any hanging flex as people are often working at height installing fibre and DC cables in the overhead trays.Use a Greg (Klik).
Also a sticker on each test point.Gold star Strima you have put a commission date on the battery a rare occurrence.
Need 6ft, largest they do is 5...Fern Howard??
No they’re not. I’ll check the make when I empty my van tomorrow.No, is your pic Fern Howard.
Just in case you've not seen these smaller sized Wago connectors - super slimNot enough room to get 4x 3 way Wagos in the fitting without them applying pressure to the PCB.
Reply to I'd rather install Ikea light fittings in the Lighting Forum area at ElectriciansForums.net
