- Reaction score
- 17,217
It's good to know my logic thinking is in alignment with the law. Cheers.
No it isn't, as pointed out in the post you quoted here the recommendation is for dedicated individual circuits, not a ring circuit.
Discuss Infra Red radiators, or........ in the Central Heating Systems area at ElectriciansForums.net
Yes. Read it.No it isn't, as pointed out in the post you quoted here the recommendation is for dedicated individual circuits, not a ring circuit.
Yes. Read it.
In the context of not having them on the main socket rings I mean.
Never even considered groups of radials though. I'll need to do some sums. Furthest room from CU will be 18 metres of cable and that was planned to have a 600w heater. Grouping that with the next room, which was planned 400w. Ideally next room also, with another 400w.
I was going to do all the marking out and chasing out for the runs. So it's all measured. (I'm not now, sparky has better tools and will be faster). I had to plan the cable runs to avoid the plumbing runs for the wet system. But now the plumbing runs "May" not be needed. Although, I really need 1st hand reports from users of Far Infra red Rads., because although I'm sure that they feel fantastic when you are in direct line of sight of them, any obstruction will absorb the heat. So, for a ceiling mounted Rad, I will be toast up top, but my feet, under the table would be cold. That makes them c r a p. The blurb from the seller claims that the objects that are heated then warm the air. I'm not convinced on that. And how hot do the objects get, at 1 metre to 3 metres away?Well that is why you pay an electrician to design and construct the installation!
That's a very precise cable length for a job that hasn't even started yet, are you certain of the cable routes that will be used?
... cos we cooked a 100A single phase pretty quicky (at an old workplace) , without using the Antique gas heater.You have a 3 phase supply?
Quoted for a 2500 litre tank, 100% buried (Apart from that butt-ugly mushroom), bunded, encased in concrete etc. 12 rads, boiler, 2 thermal stores in loft....was £16k. Not much more, but more. Boiler was the ugly outside style though, I think they are more expensive than internal types due to waterproofing. Dunno, we've dismissed oil due to all the fecking about with it. And, as most of the nation needs electric, the prices will stay "Balanced". Whereas oil will increase more. Pellets will probably increase too, because why should market forces give a flying feck for a few thousand homes with pellets/oil. If you see my drift.Hi - I thought an oil fired boiler, bunded tank, rads and pipes etc would be substantially less capital than £14k you've been quoted for biomass ?
Reply to Infra Red radiators, or........ in the Central Heating Systems area at ElectriciansForums.net
