So I am trying to install a ceiling fan with lights, there is a switch location closed with an empty plate and ceiling fan point installed.
When I open switch location, can see there are total 5 wires, 2 black, 1 red and 1 ground - white ones are already connected to each other.
I am planning to install a single pole switch, where both black wires would go the bottom and red one would go to the top and ground will go to it's corresponding location.
Ceiling fan would be controlled with it's pull down controls for both light and speed. Is this feasible plan and right way to connect it? Thank you for all the help.
