• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Installing meter for stand alone garage - South London in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Hi All,
I live in a building with about 100 flats and 17 garages, of which one garage is mine. Based in South London, SW2. The garage currently doesn't have electricity which is something I would like to change.
I know at least one other garage has electricity installed and this is wired from a box just outside my garage which contains a few meters (one for his garage, one for communal areas and a few others I'm unsure of).
Given there's a supply just outside my garage I believe this should be a fairly easy installation but I was wondering if anyone here would know how to best go about this, as I have never had a new meter installed before. Would it be something that is run by the managing company given it would be installed in a communal area and do I just tell my electricity company that I now have two meters?
Assuming just a simple wire in to the garage with a couple of sockets, what would something like this cost?
Thankful for any input you might be able to give.
You would need to contact the company that manages the building or your landlord if different, before making any alterations.
If it was agreed you could install an additional supply, separate from the building owners, you would need to contact your local Distribution Network Operator for a quotation.
And just because there is an existing supply nearby doesn't mean it has enough spare capacity for another garage.
The D.N.O may refuse connection or quote to upgrade the existing.
Reply to Installing meter for stand alone garage - South London in the Electricians Jobs area at ElectriciansForums.net
Hi there, This might be a bit of a long shot, but doesn't hurt to try. I'm based in South West London (Richmond/Twickenham) and I'm about 7 weeks...
Hi everyone, I'm currently working towards getting qualified as an electrician and am hoping to get my foot in the door with an apprenticeship or...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
