Discuss IR fault on ring in the Australia area at ElectriciansForums.net
J
johnnymacc
Hi guys,
did a cu change in an indian takeaway,fighting the clock,split the ring and thought i had the prob sorted so put socket back on then got 0 reading did this with a few sockets, they were old and pretty gunged up do you think this was the prob off back tomorrow with four new sockets also cos its a small place with one ring i was struggling to suss how it was wired,any thoughts.
Likely there is a load in the circuit you havn't identified. Try removing the sockets you are suspecting and put temporary connections in their place.
Then re-test.
I think the extractor fan system is run off the ring cos it wasnt working and i didnt realise till the owner said the fans not working as i was leaving
Then re-test.
Wago's are the dogs for doing this. I had a line to earth short circuit on a kitchen ring on Monday, turned out to be a very cheap poor quality chrome socket that someone had got in a lucky bag for about 10p.
Cheers.......Howard
was this line to earth or line to neutral? i normally just do a quick continuity check line to neautral, if you get continuity generally there is still a load somewhere, join the line and neautral together on one leg at the board then test line+neautral together to earth, see if its any better.
you could always do a continuity between the cpc and N and L and cpc this will confirm you've not got a short to a back box some where ,if ok do as keith has said it could be as been said an appliance still plugged in , dont forget to re do your IR tests if you do find a fault or appliance plugged in
Nick
Reply to IR fault on ring in the Australia area at ElectriciansForums.net
Hi everyone, Hope everyone is keeping well. At a property Fault finding prior to consumer unit upgrade. Amazing that some bright spark thought it...
Did a check on a ring circuit, due to board having to remain live I did it at a socket.. Was an RCBO, had checked RCD side and all tested ok...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
So a customer had a nuisance trip and I spent 4 hours trying to find the fault (first hour identifying circuits as none labelled at board). There...
