A
acat
Hi Folks
Got a partial rewire/conversion to do soon. Customer wants an electric toilet never seen one never mind fitted one has anyone done one of these and can advise what problems I might face or are they easy peasy.
Chris
I would google my man then look on the tech/design specs of suppliers of Electric toilets . Or is this a wind up
Thanks Durham the perfect model:). No its no wind up Daddy has one in Germany and what Daddy has she has to have think its one of these eco jobs she just happened to mention it this morning to the Mrs.
I will take pics and post what I find so that everyone else is aware.
Chris
Put some in once and they were a piece of pee, can't remember the model though sorry they were customer supplied. Literally straight into a fused spur I think I ran a circuit for them but they could have been put straight on the ring I'm sure.
RCD, obviously.
Is it a saniflow unit? If so it's just a bit of flex to a fuse spur, My uncle as one downstairs.
are then saniflow units designed for using small bore pipe work and normally associated with a maserator to chop the turds up..! fitted in areas that a standard waste pipe is hard to install/impractical to istall..!!
may be wrong, In my Navy days.. (haha look at me only left in feb, im like uncle albert from Fools and horses) we had maserators installed on the bogs, brillaint design but they used caravan type ones with plastic blades...! just imagine 130 blokes going for loads of poo and guessing how long the blades lasted till destruction ....!! normally life span of 100-150 decent poo's or 5- 8 days..!!
Saniflow units have a small bore waste pipe outlet normally sits behind the toilet pan maserates the number 2's and pumps them away
As already said FCU adjacent the toilet
There is also the one that is built into the toilet so it looks like a 'normal' lav.....As stated, fused spur is fine
big problems with saniflos specialy when in the "Ladies" lav they put allsorts down them crackin Idea but in practice needs some sence shown by user
