Discuss joining two feeds into one consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
I am only putting up the trunking around the perimeter of the workshop. There are loads of options where to put it as the roof trusses are exposed and make a great network of supports. If the sockets can go on the back or side it will be a neat job. He'll tell me tomorrow at the site visit the best option.
Fix it to the wall perimeter for ease of installing circuits & future maintenance & access. You wouldn't want to be working on steps or ladders if can be avoided.
Would it be ok below the windows? There is no room above the windows, they go to the top of the walls. I'm worried about splashing coolant onto the trunking.
Now you are adding other issues as to the IP rating of Trunking which you will need to ask the manufacturer as not all may comply with Standards. At least IPX4 , now you are talking coolant, is this corrosive?
I thought higher would be better as the trunking at my factory is at least 10 feet high it does not get splashed. If I fixed it to the top of the perimeter wall it would go over the windows but I suppose it will be ok.
Good morning.
The dno can install the 3 phase meter box directly ouside the wall of my current meter which means that they can connect 1 phase directly through an existing hole in the wall and sort out the meter etc.. I'm very happy about this, nice and simple and neat.
For the rest of the property the Electrician has asked me to run a 16mm 3 phase swa for him to connect up.
The first run will be about 15 metres from the new meter box to a 16 way 3 phase distribution board, replacing the existing cu. This will service an existing large garage/workshop, pool heater system and a flat + family room ( man cave ) both above.
The second run will also be 16mm 3 phase swa for about 25 metres. This will run from the new distribution board to another 16 way board in the new workshop.
My question is.
From the new meter cabinet to the new distribution board ( the first run ) I will have 2 redundant 16mm single phase cables that are buried and run exactly the same as the 3 phase cable I have to install. These two swa cables are plenty long enough to connect from the new cabinet to the new distribution board.
You can guess the question - can I use one existing swa for 3 phases and the other for the earth and neutral.
Reply to joining two feeds into one consumer unit. in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
