Discuss Kitchen appliance FCU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It isn't a requirement for FCU's to be used for kitchen appliances ie dish washer or washing machine is it in a new build? I was thinking of just putting a double socket in a cupboard and plugging in the two appliance but have read about using FCU's and was wondering if this is a requirement or just a recommendation?
For two heavy loads like these I personally would run a dedicated radial, but that's just my personal preference nothing to do with the Regs, others will say different I'm sure.
Sorry my apologise it will be a small dish washer and small under counter fridge. Running radials for appliances cant really be an option. The ring main would consist of 3 counter top doubles and a double low level (under sink) for dish washer and small fridge. Is this adequate? Just reading up on dilating appliances via fcu was mentioned and got me thinking is that how its required now or just a recommended way of doing things
Put in 2 separate single sockets on a dual surface box if its a WM and TD and keep on the ring or run in a separate 20a feed.
If its 2 smaller loads like DW and FF then a double socket on the ring or even spurred off the ring is fine
DO NOT cut off the manufacturer melded plug top
If you can provide evidence to the fact, that it can affect manufactures warranty (if thats what you're suggesting). That would be useful.
I've had a washing dryer & dishwasher adjacent to each other on an RFC, and the world didn't end. You have to remember these appliances are more efficient these days, although I'm sceptical with my current fuel bill.
the reason for fitting a FCU or a 20A 2 pole switch above worktop is basically to provide local isolation for the appliance without the need to pull the appliance out to unplug it. if the plug/socket/s are accessible, there's no need to fit FCU or D/P switch.
[automerge]1571381483[/automerge]
mornin' pete. up early?
Reply to Kitchen appliance FCU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
Hello everyone, We had an electrician over, who fitted a 40a MCB in the house consumer unit to supply a new build garage. It's underground SWA...
