Discuss Kitchen island socket back box in the UK Electrical Forum area at ElectriciansForums.net
Hi All,
Having a new kitchen and the Mrs wants a socket on the back end of the island, does anyone have any back box suggestions?
The socket will back onto a cupboard so I want to avoid a drywall back box due to it not being very sturdy.
I would appreciate your suggestions. Thanks
Dunk
As well as they usual galvanised back-boxes, you could use adapt something like the MK metal-clad back box to be flush-mounted as it will take the usual white domestic double sockets, etc, and will look a bit nicer from behind (and less risk of catching the back of your hand on any corners).
This sort of thing:
https://www.NoLinkingToThis/p/mk-3-4-module-metal-clad-box/32511
What about a flush mounted worktop socket unit rather than a standard flush socket-outlet?
The thing
Less chance of the socket filling up with unwanted food items etc and can be dropped down when not required. These plug into a nearby socket-outlet and act as an extension lead so are designed for light use such as food mixers etc.
The thing
Hi Strima,
I want to try and avoid a pop up socket because it will take up cupboard space and there's a sink on the island so likely to get splashed
galv. back box. fix inside with a couple of angle brackets.
Hi Strima,
OK, I get you now, I thought worktop mounted.
One option is to cut the shape of a 25mm patress box into the unit then use timber at the back to support it. This way you can mount a socket flush and still maintain the IP rating internally in the cupboard.
You can use a standard galvanised flush box and fix it into the sides of the cut out through the small holes near the front edge of the box.
Reply to Kitchen island socket back box in the UK Electrical Forum area at ElectriciansForums.net
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
