Time my old mate the sooth came back for a visit, so the question is .....................................
Come on son gives us a little clue is it a big motor or a little motor, is it a nice blue one, or that horrible grey type, does is go whirrrrrrrrrrrrrr or hummmmmmmmmmmmmmmmm,
Ezze did you take in account the angle of the dangle or the heat of the meat, if you do and then √it by Π taking of course the coefficient of 0.35268 and then multiplying by the root factor of 0.09841 then you can see it is as Doomed said ..................42
a problem with 11kw motor.
needs a 15kw star/delta starter have got
overload contacts rated 18-24amps
motor start up in star 20.4 amps
running in delta 11.8 amps
the manufacturer has told me that it is a beast to start due to the high currents needed , they suggest fuses, a bit difficult as all distribution boards are circuit breakers. allowing for 6x start up current, can anyone suggest what rating circuit breaker and what type to use
Not sure if understand your exact setup here. The overload needs to be set closer to the run current. An overload set at 18A with a run current of 11.8A leaves the motor wide open to overload damage.
Your question about the circuit breaker I would suggest that the MCB would be appropriately sized for the cable it's supplying, not for the load being driven.
o.k. so the overload to be set at 11.8 amps, not a problem
at the moment 4.0mm 3core armoured on a 32amp triple pole type c mcb cannot hold it in. after calculating the size of cable through a software porgramme, there didn't seem to be an issue with the size of cable
An 11KW motor at 400V, .85PF and 90% efficiency comes to 20.2A FLC. For star / delta the O/L should me set to 20.2 / √3 = 11.7A. A bit bigger MCB I think.
i was thinking of a 32amp type d triple pole mcb (merlin gerin)
i had a similar problem with a three phase compressor (again no help from the supplier and manufacturer!)
I would also imagine a 32A D-curve MCB would be fine in this application.
If the motor is dirving a fairly constant load I wouldn't be afraid to check the actual running current with a clamp meter and set the thermal overload even lower the calculated 11.8 Amps if you can. I tend to err on the side of caution and set them as close as possible.
I also try to spec the thermal so the setting is toward the upper end of it's range that way if some muppet twiddles with it there's still a good chance it will do its job even on its highest setting. In this case I would go with a 7-13A overload rather than one with a range of 11-16A for example.
