S
Snapester
So i heard a fellow sparky saying taking L&N to the light switch is not allowed and is classed as bad practice!
Is this true I've found it a good way to keep things tidy when wiring lots of spots etc.
Thoughts?
He's an idiot, take no notice of him. Or you could put him on the spot by asking what reg number prohibits the practice. I would.
I find it's a good way of keeping things messy in a switch back box if you aren't careful.
I have no issue with installing this way if the situation calls for it though.
I install like this when it's appropriate. As Trev says, get him to point out the reg that forbids this method... should be good for a squirm.
I know of a reg number, take a look at this: 559.6.1.100 in BGB, or in the BYB 559.5.1.208
You could point out that hager switches have a neutral termination on their light switches. I cant see any problem with this method and use it most of the time myself.
That reg says "consideration" so tell him to sling his hook if he wants it wired at the switch.
Nothing wrong with that , makes good sense when fittings are compact and avoids concealed joint boxes , good for testing and fault finding as well..
Just remember if using a connector block for neutrals it requires to be fixed to back box,
we just use wago's not fitting back can just be left loose
what reg. says connector block must be fixed to box?
