Discuss Laptop charges off 12v battery/inverter when full, stops after a while in the UK Electrical Forum area at ElectriciansForums.net
T
tara1234
Hey so I have a 300W inverter and a 24ah 12v battery. This works to run and charge my laptop for a couple of hours, however after a while the laptop stops charging but I can still charge my phone off the USB that the inverter comes with.
Can someone explain why this might happen, does the battery need a certain amount of AH to be able to put out power. So for example when my battery reaches say 6AH/24 it simply does not have enough to power the 300W inverter?
Hey im not that sure, I think it is probably deep cycle it says for industrial standard use. It is a yuusa valve regulated lead acid battery.
Update: I plugged my little netbook in which uses a much weaker supply and its charging. But doesn't work with the big laptop until I fully recharge the SLA.
Big laptop PSU
input: 100-240v 1.7a
output: 19.5v 6.15a
Small laptop
input: 100-240v 1.3a
output: 20v 2.25a
Real world results ,can be confusing . A cheap Digital Multi-meter on VOLTS
my help you understand what is going on .
( and things that will harm your battery - like discharging Too deep)
From you results , you may be on a slippery slope .
(If it turns out to be a starter/CAR battery - they are awfull at what you want !)
A decent charger is also needed to keep things healthy .
What sort of room temperature is this all happening at ?
Its about 15-20 Celsius.
When I plug my big laptop into the inverter the charger stops working but the small laptop works fine.
Right playing with some other batteries.
a 12 ah (Fully charged) one, chargers little laptop fine, big laptop it flickers on/off with the charging.
So by this assumption does this mean that the battery needs more than 12 AH remaining to be able to charge my laptop?
If you've only been part discharging then recharging the laptop battery over a period of time, then it's possible that the battery can no longer accept a full charge.
You could try a few full discharge / recharge cycles to recondition the battery or you may need a new laptop battery.
That sounds reasonable , In-efficiencies are your enemy .
Even the charge cycle is in-effiecient !
(I cannot be much more help without knowing voltages )
As described , battery sounds like it's struggling at higher load or weakness elesewhere.
Check you 12V wires for any warm patches , showing poor connections,
while using higher load nextime .
( Take care as I've witnessed a wire cutting into a duvet -12V- no fuses )
Also since both batteries have some power but are not enough to deliver a charge. Would connecting them in parralel allow them to give a high enough charge to get the inverter working or is it a bad idea to have batteries of different sizes connected to each other.
Iv heard its a bad idea while charging them but what about discharging them?
Combined is bad news , especially if voltges are un-known .
( only stands a chance if near identical -type/age/health ..and even then
they drift apart )
A few seperate load tests with a voltmeter help compare health and which may need more charging . ( bye/late )
Tara, I'm going to suggest something radical... how about asking your landlord if they'll get a power outlet or two installed in your room?
I find it hard to believe that it's not a requirement to have at least one outlet in each room. I'm assuming it's a house of mulitple occupation, or you're renting a room as a lodger.
Hi SC, you may be surprised what the landlords of HMO's get away with.
Unless tenants complain to the landlord then nothing will get done, if the tenant complains then it's often bye bye & next please.
It's a vicious circle really & councils don't do much until there's a real stink created by someone or God forbid someone gets hurt.
I wouldn't be surprised, I must admit I went looking for info about minimum requirements for HMOs when Tara first posted about this and the jumpstarter she was using. All I could find was minimum requirements for kitchens. Other than that, it does seem it's entirely down to the landlord, which I thought was shocking.
But, based on her first post, if I was planning on being there a year, I'd be asking the landlord if they'd do something about it, especially in this day and age when practically everyone has at least one battery operated gadget that needs regular charging.
To be fair, the majority of landlords are pretty good & give their Tennant's decent accommodation, especially when they're expecting colleges to send students their way.
But some of the others can be really bad, some of the HMO's around Pontypridd a few years back were atrocious.
Can we go back to basics?
Why are you trying to use this set up?
From the OP's info, I'm guessing that this is for use on a boat.
How do you plan to charge the 12V battery?
Tara originally posted about using a jumpstarter pack to power her laptop in her room (via an inverter I believe) in a house. The issue was that the jumpstarter pack took a very long time to charge. She was advised to use (if I recall correctly) decent lead acid leisure batteries and a charger specifically designed for the purpose.
I'm assuming this is a continuation of that saga, I could be wrong.
^^ guessing isn't going to help.....
We need facts...
I tried an inverter on a canal boat..... It only worked when the engine was running
and cheap inverters produce a shitty output waveform
A laptop PSU designed for a 12V input is much more efficient, mains inverters are very wasteful and will drain batteries quite quickly. I get about 3 hours heavy charging out of my 12V 7AH SLA battery when connected with my 12V laptop charger, your 24AH battery would last much longer if you ditched the inverter and got a 12v laptop charger.
Agree with Fredd0 - no point stepping up from 12V to 230V and then back down to 19V with 2 lots of inefficiences. Use a 12V laptop charger and ditch the inverter (which is probably a horrid cheap quasi-sine wave output anyway).
Reply to Laptop charges off 12v battery/inverter when full, stops after a while in the UK Electrical Forum area at ElectriciansForums.net
Looking for advice for how much power I can reliably get from a dual battery system please (note it will be installed by a professional, I am just...
I live in the Philippines where the power is bad, we have constant outages and when it does work the voltage ranges from 160-255v and the hz...
I thought I had an understanding of how to size an inverter but I think I have become slightly confused after taking to some proposed installers...
I am mostly curious as I don't think this is a very important issue. In my bedroom I have 2 overhead recessed LED lights that are not on a...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
