Discuss LED Downlighters - Any good? in the UK Electrical Forum area at ElectriciansForums.net
Dan
Staff member
Admin
Mod
My downlighters keep blowing. Apparently LED's last a lot longer.
Any good or what? Don't fancy replacing them all if they're just going to pop or whatever too.
decent LED lamps will last ages. some even carry a 40,000 hour warranty. try diamond LED co. halers,kosnic, and any more you can think of. need at least a 7 watt LED to be equivalent to a 50w halogen. i assume you've got GU10 mains halogens not the 12V ones.
Where have you been the last year or so? :lol:
For complete replacements I think the JCC ones are spot on
For retrofit lamps, never had any problems with Philips, Kosnic, GE, Robus or LEDlite. There are many options, changing to cool white lamps in my kitchen and bathroom made the rooms feel so much nicer to be in
Dont buy the cheap ones or they'll last a lot less than the halogens
Remember the difference in colours too, white are brighter but are a cold light, where as warm white dont seem as bright but are a warmer light.
i call this "dirty white" - just think it looks cheap compared to Cool White - would recommend Knightsbridge range of downlights and GU10 LED for decent qulaity at a competitive rate
Reply to LED Downlighters - Any good? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
