Thanks, you all, I initially thought it would be easy as a new driver replacement, but when I couldn't find the exact part knew I would need some tech knowledge to figure suitable alternative.
Since the first driver packed in a few months, another 3 lights have started starting to flicker, hence relooking at options to sort this out.
For the LED panel load, I will have to double-check, I did have pictures but can't seem to find them. I will need to reopen the lamps
So, am I understanding this right, that I will need a LEDset driver matching the set output current and voltage and use the current resistor, will I need anything extra for the Dali drivers?
Just on a side thought, the lights are currently being used through the breaker rather than the override switch or BMS system, could this be causing the drivers to go faulty prematurely?
