Discuss LED Light Strips in the Australia area at ElectriciansForums.net
X
xantia31
Hi Guys
Im no electrician but hope you can help.
Ive recently fitted led light strips to my car. I had them on my prev car with no probs. Just disconnected the side lights and joined the 2 wires up!
Done the same on my Saab and when they engine is running with the lights turned off, they flash alternately. They also do this for about 2 mins after ive switched the car off and locked it up. Obviously they are picking up residual current and i can just drive with them on all the time but in the summer i would rather not.
I bought a couple of resistors (?? ) and tried fittin them in line i.e chopping the live feed and droppin it in but to no avail.
Any ideas?
PS Sorry if this isnt the right place to ask this!
John
Hi Guys
Any ideas?
John
I thought saab lights,like all swedish cars all stay on the whole time.If so you would need to fit a switch??Dunno about the flashing lights though,have you tried swopping the wires round,might be a polarity issue,as diodes are polarity sensitive.
im sure these lights are illegal (well depending on colour white at front and red at back are only ones legal iirc)
why not put them on a seperate switch
Sounds like maybe the ECU has detected something isnt right and its giving a warning.
Either that or its throwing a wobbly due to the load thats now been put on it.
Reply to LED Light Strips in the Australia area at ElectriciansForums.net
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
Hi all. I just wanted to see if anyone has had issues with Fans on the same lighting Cct as LED strip lights. I have a job where the fan mech on...
Hello, I've installed a Monsoon Extractor Fan kit today, all is up and running and everything is working with the exception of the LED. When I...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
