Discuss LED lighting strips in the UK Electrical Forum area at ElectriciansForums.net
A
alex30
I am looking at producing a production light for filming using natural white light led strips. I will be using 3 5m reels rated at 12v and 2A/5m. I am looking at using 100cm length (therefore there will be 15 100cm lengths) and was wondering whether it is best to have them in series or parallel and what sort of power supply to use. Ideally I would like to have a way of diming the lights so could something like a potentiometer be used?
An help and advice would greatly appreciated,
Alex
The strips would normally need to be connected in parallel, the strip will be made up of lots of small series string connected in paralell onto the main power conductors.
Your best bet for dimming would be to get dim able ballasts. Using 0-10V dimmable ballasts would allow you to use a single pot to dim them all.
I used these Waterproof Cool White LED Strip Lighting strip lights 3528/5050 30CM 1/3/5/10 M | eBay (5m +power) in my kitchen they can be cut every 3 leds and tails soldered on to the board so can be made any length (i used hot glue to reinsulate the tails after soldering) unsure if they are dimmable though depends on the pcb used. conect in parallel as mentioned earlier
theres a dimmer I pondered over buying for another project here LED Strip Inline Dimmer switch for all dimmable 3528 5050 strip LED Tape | eBay
but not tried it yet. (dimmer will only do 5m )
I used these Waterproof Cool White LED Strip Lighting strip lights 3528/5050 30CM 1/3/5/10 M | eBay (5m +power) in my kitchen they can be cut every 3 leds and tails soldered on to the board so can be made any length (i used hot glue to reinsulate the tails after soldering) unsure if they are dimmable though depends on the pcb used. conect in series as mentioned earlier
Don't connect in series!
The strips need to be connected in parallel, they are made up of many small series strings connected together in parallel which is why you can only cut in certain places.
Reply to LED lighting strips in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
Hi Guys Never used LED strip lighting before. Customer wants the cornice strip lighting around bedroom so I can access loft space if required...
