Discuss LED lighting in the Australia area at ElectriciansForums.net
R
Ross Trician
Good evening folks.
I have a customer who I am planning a rewire for and ther are asking for LED lights for in treads, wall washing, down lights etc....
I am aware of the general down lighter spot lights etc but whilst browsing the web for ideas, styles, costs etc I see some stuff is 240V supply where as other stuff requires a driver.
why is there a need for a driver? what are the benifits of 240V and "driver" type led stuff? what are your own opinions of them, any particiular brands that are good quality over other poor stuff.
thanks, Ross.
Re: LED lightining
Good evening folks.
thanks, Ross.
We have installed different LED lighting in numerous jobs. The simple ones i.e. Philips or Aurora LED GU10 lamps dont need a driver and they are dimmable. We have installed Robus and Cooper LED lights - these need a driver. The driver is the control gear and you can have standard switchable or dimmable drivers for most LED lights. Yes you need to be careful LED lamps are entirely different, it's new technology and is at the moment changeable.
Re: LED lightining
thanks for the reply, I dont want to sound dim... but why do some need the driver, do they do something different? am I correct in saying 240v led lamps are for example gu10 lamps, where as say a 3watt led spot needs a driver?
a 240 LED gu10 will have the driver "built in" much as a CFL lamp has the control gear built in instead of needing a ballast like a normal fluory
Reply to LED lighting in the Australia area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hello, I’ve have some ten year old Collingwood SL020 RGB led garden spike lights which I’d like to keep using but wondering if I can use them with...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
Hey folks, i work for a relatively small company, but we are doing some big jobs. And right our headache is taking over outdoor lighting...
